connections
hooker128
connections
hope there are some experts out there, right here we go. What is the best way to connect the tv to a skybox/a blue ray player and a sony dav-dz260 theater system, all components are sony, hope you can help:smileyconfused:
Bravia55HX
experts?, what are they?, joking aside and assuming you want to use the DAV system for the surround, you can try the following- connect the sky box via HDMI 1, the blu ray to any other HDMI, then (fortunately you have both) for the surround sound, connect the blu ray up using a Coaxial Digital cable to the DAV and if you wish connect the sky box with a Digital Optical cable to the DAV, check the menu settings on all units for sound and you should be ok
