Differences in TVs W6
Helllo.
As I found on different sites, there is only one difference between KDL-32W653 and KDL-32W655:
 - KDL-32W653 supports Analog, CI+, DVB-C, DVB-T, DVB-T2  (no sattelite)
 - KDL-32W655 supports Analog, CI+, DVB-C, DVB-T, DVB-S, DVB-S2  (no DVB-T2)
(KDL-32W654 and KDL-32W656 seems to be just in another color).
Am I right?
And is there any Sony TV model that supports all types of tuners (Analog, CI+, DVB-C, DVB-T, DVB-T2, DVB-S, DVB-S2)?
Thanx
profile.country.de_DE.title
traesig
the W653 is the UK model, the W655 the german model, therefore the differences in the tuners. If you want all standards supported you need to go for the W656 in 50inch or an W8, W9 model
traesig
