Does the presence sensor stop viewing too close to the screen?
brightonrock
I have a KDL46EX703 which has a presence sensor. I was told by the shop that appart from detecting no movement and after a preset time putting the set into standby it could also detect if children were sitting too close and blank the screen. I cannot find the "sitting too close" feature. If it is available how do I activate it?
If not does anyone know when Sony are planning to introduce it. (The shop said Sony had told them about the feature)
Thank you
Thalamus.
Champion
Hi brightonrock,
welcome to Questions & Answers..:smileyhappy:
Unfortunately according to the KDL46EX703 specifications it does not appear that your Bravia have the 'Distance Alert' feature..
More information on the Distant alert feature can be found using the following link - Bravia Smart Features
Thalamus.
Champion
Hi brightonrock,
