Help I've a Sony KDL26EX320BU - Dec 2011 brillaint 26 in TV
BUT when i turn on or off the external DVD player connected to HDMI 1 it does NOR take control of the TV screen. I have to manually use the TV remote.
I've never had this problem with a TV before.
If ther is a setting I need to configure let me know
Message was edited by: philipstanfield
Solved! Go to Solution.
not sure if your tv supports this but try it,
go to menu- external inputs- scroll to HDMI set up, then turn HDMI control to on, check in HDMI device list for your player and enable, that should cover it.
