EX 503 - Motionflow/100hz
homerhotspur5
Can anyone clarify exactly what the motioflow feature does in each of its 3 settings. Is it the case that when it is ' off', the set is at 50hz, then 75hz at ' standard' and 100hz at 'high' . If not, what does each setting do?
Pcadjb
     I assume you have already checked out the following page on the UK Website,
http://www.sony.co.uk/hub/bravia-lcd-televisions/2/3/article/motionflow
I also found information on the Sony USA site, which says there is a setting for movies which I assume is the standard setting.
So in summary
1. Off - No Motion flow 50fps (Frames / second)
2. Standard - For Movies / animation to have a cinematic feel
2. High - For high speed objects (Sports etc) 100fps
