faulty bravia KDF-E50A12U (rear projection)
frasteel73
hi all , i have a rear projection bravia about 7 years old . the power light flashes red twice goes green for 2 seconds then keeps repeating. can anyone help please .
Hi there
2 blinks indicates a short in one of the power supply circuits (B+ Overcurrent protection).  Therefore this is a hardware fault.
You will need to contact an authorised Sony Repair Centre to get this fault diagnosed and fixed.  However being that the RPTV is a number of years old now, it might be uneconomical to repair.
frasteel73
ok cheers thought it might have been faulty bulb but didnt want to buy one in case it wasnt!
thanks
