HDM1 Cable is Missing
Keyman_1388
Hi, I just bought a brand new
KD-55X7000E TV. But unfortunately it come without the HDM1 cable.I have never seen such this before, and usually this cable comes with it.So is this normal gentleman, because when I opened the box, I didn't find anything.I used to purchase a Panasonic TV and it had came with it.
Sean_Mc
Moderator
Hi Keyman_1388,
I've checked and the TV does not come with a HDMI cable included. To my knowledge I have never seen these cables included.
You should have the following in the box -
AC Power Adaptor
AC Power Cord
Batteries
Operating Instructions
Quick Setup Guide
Remote Control
Table Top Stand
You can find more details also here.
Hope this helps.
Cheers,
Sean Mc
