HDMCP compatible
Madqwer
HDMCP compatible
Hi I have a KDL-40Z4500 TV I would like to know if my TV is HDMCP  COMPATIBLE  as I have a apple tv and it won't play film trailers
Catmambo
Hi
Do you mean HDCP  -http://en.wikipedia.org/wiki/High-bandwidth_Digital_Content_Protection ?
If so then yes - if you have connected Apple TV to the BRAVIA via HDMI cable then yes. I think HDCP is mandatory.
Hope this helps
Catmambo
Hi
Hope this helps
