HDMI inputs on a KDL-46X3500
anholbr72
Hi, is it possible that all HDMI inputs on a KDL-46X3500 can fail at the same time?
Bravia55HX
i would say its possible yes, however before you believe that is the case here have you tried other HDMI compatable devices with this tv?, for example it may be the blu ray players HDMI output that has failed, you would need to eliminate this first, if nothing else works then its likely to be the tv in which case you will need to refer this to a Sony Authorised Repair Centre.
anholbr72
OK many thanks for your reply. Unfortunately I had tried your suggestion (and other senarios) TV works fine on other inputs, as do the devices, HDMI cables on other TV's. Gutted!
