HDR picture settings??
Beansafc
Can anyone tell me how to get a good picture using the HDR setting on the xe70?? The standard settings are truly awful,had this tv a month and really disappointed compared to the Samsung I had to replace
EdwinaU
Moderator
Hi Beansafc,
Welcome to the community.
You will find some instructions here to help set up your TV to detect HDR content.
Best wishes,
Ed
dhw666
My advice is that you turn off all the "enhancements" as they end up making the picture look awfull. It was the case with my old sony 3DTV aswell, I had to turn everything off.
For example:
HDR netflix (app) just looked terrible because of motionflow. Turning it on ment I had lots of artifacts that looked like poor compression when things moved fast and turned off, they were gone but the framerate just stuttered (wasn't smooth).
4K HDR movies from my pc with all the "enhancements" and motionflow turned off looks amazing.
