help
profile.country.IE.title
wilmcgee
help
can I browes the internet direct with my 40hx853 and how ?
Thalamus.
Champion
Hi  wilmcgee,
have you conected your HX853 to your network.?
Here is guide should you need it - How to setup a Wi-fi connection
Once you have connected to your Bravia to a network then you should be able to browse the internet by doing the following..
  1. Press the HOME button, then select [Applications] at the bottom of the screen using the / buttons.
  2. Select [Internet Browser] using the / buttons, then press the button.
To enter a URL press the OPTIONS button, select [URL entry], then enter a URL
Thalamus.
Champion
Hi  wilmcgee,
wilmcgee
I got going with the net but now as I sometimes stream sports on the tv I am having a problem eg. I log on to firstrow but I cannot find how to click on link to connect if you turn on firstrow you will see you have an option of different links but I cannot find out how to get it to go to the link ?
