HT-NT3 Sound bar
mkj1972
HT-NT3 Sound bar
I have recently bought a HT-NT3 sound bar to go with my Sony 3D 55" curved TV,however when I use the volume control on the remote for the sound bar the volume on the tv adjusts as well.
Is this normal??
Or is there a way to alter the volume separately on both units??
Thanks Mark
13 REPLIES 13
mkj1972
Thanks for the replying I will try that I have got another HDMI lead I can try
no I didn't change any settings but I did buy a to box that is plugged in & working
i will let you know how I get on
once again thanks for your help
royabrown
Enthusiast
@mkj1972 A to box?
Probably a typo, but if we knew what it was meant to be, this might help.
And if 'to' is a typo for 'TV' we will need a little more still....
YouView Superuser, but not an employee of YouView, nor retained by them for this purpose. It's purely me speaking
mkj1972
Sorry I meant tv box that's predictive text
I have unplugged the tv box & now the sound bar is working again!! Wierd
thanks for for all your help folks
Johnwithsony
I  have similar problem but my sound bar has a fibre optic cable link. How do you get the tv remote to control the sound bar volume and also switch the sound bar on. I have to use the sound bar remote to control the sound bar
