HUB PIN NUMBER ENTRY
Mcflewster
How do I enter a PIN number when Connecting to the Internatet with my KDL 22EX553
Catmambo
Hi
As part of the Network setup process, it will normally prompt you for a WEP/WPA code right? This is normally where you type in your routers code I think.
