HX853 Game Mode
bopetickle
HX853 Game Mode
Just got a 46HX853 and have an xbox 360 plugged in via HDMI. When I have this selected I had hoped to be able to turn on "Game mode". However when I select Picture options I only have Standard, Vivid and Custom. Per the iManual it seems there should far more options including "Game Mode". This is true on all HDMI inputs and Digital TV. Am I missing something simple?
Thanks for your help.
profile.country.FR.title
ClarkLong
"Game mode" is located under the "System>Sytem Settings" and not under "Display".
squarejawhero
I've got the same problem on a 40" of the same model - I'm using a 360 via component and there's no game mode option? It's a bit odd and can't for the life of me figure where it is.
ClarkLong
squarejawhero
Ah, yes, found it. Finding the menu's a bit obtuse but I'm getting there! Trying to solve a colour correction issue now... fiddle fiddle...
