image readability
kerronk
image readability
Browsing on my bravia by wifi from my computer, why are some images not opened, all are .jpg?
8 REPLIES 8
Catmambo
Hi
Try out Sony Homestream as I think this will resolve your problem - www.sony.co.uk/homestream
kerronk
Unfortunately all the bother of installing etc Homesteam hasn't made a scrap of difference. Why do some images, which display on every other device I own, refuse to be displayed by the Bravia?
Convergence
Hi if you edit photo's in PhotoShop do not use high quality JPEG with 4:4:4 as the support pages will give info under heading what codec are supported;
Supports DCF2.0/Exif2.21
YCbCr4 :4 :4 not supported
kerronk
Regardless of where or how the images were edited and without any common theme in properties- Why do some of them, which display on every other device I own, refuse to be displayed by the Bravia?
kerronk
since every other device that I know of can display JPEGs processed by an Adobe product I think this is clearly a Sony Bravia issue.
kerronk
Anyone attracted to the feature whereby photos can be viewed on their TV (no-one prints anymore) will be very disapointed with a Sony Bravia - Its clearly not fit for that purpose.  Why have the Sony people I see on this site not put their hand up and come clean about the issue? What a sloppy outfit!
kerronk
I have now thoroughly tested what will display on my Bravia and what won't.
It seems that provided an image has not been 'processed' by PhotoShop (by me or before I received it) - it will display OK
Anything that has had a 'save as' in my PhotoShop elements will not display regardless of whatever else has or has not been adjusted.  Also nothing I do can 'undo' the problem
I would be tempted to blame PhotoShop but come back to the same conclusion - why, if every other device displays correctly, does the Bravia fail?
Are Sony happy for me to have a faulty product?
kerronk
