Inputting WPA code characters
pcy961
I'm attempting to connect a KDL32CX523BU using the UWA-BR100 dongle. All is going well until I start to input the WPA security code for my network. I can't see how to input the characters "," and "-". I've tried all the coloured buttons to get capitals etc. but these characters just don't appear. Any ideas?
Thalamus.
Champion
Hi  paulcyates,
welcome to Questions & Answers..:smileyhappy:
The options to select characters should be shown below the password box..
for example Red a/A & Blue 123/!:?..
Are you able to find the option for character input at all or just not the "," and "-"..:smileyconfused:
Failing that there is always the option to change your network password to something with upper/lower case & numbers..:smileywink:
Thalamus.
Champion
Hi  paulcyates,
pcy961
Many thanks. It turned out that by pressing the blue button more times than I had before the characters I needed appeared. It's all sorted now.
Thalamus.
Champion
You're welcome..
