Is Media Remote compatible with BDP-S480 Blu-Ray Player and RMT-B109P remote control ?
profile.country.fr_FR.title
faubry
Hello everybody !
My question is in the title.
Indeed, I am using the Media Remote application from Android and I would like to be able to control my BDP-S480 Blu-Ray Player with it.
However, it looks like the application does not show the RMT-B109P remote control as available.
This is very strange as when I was offered this Blu-Ray Player, I remember seeing the "Media Remote" logo on the package.
Unless there is another remote control compatible.
In this case, would you have any idea of the remote control code I should use in this application ?
Thanks in advance.
Best Regards,
Fred
Catmambo
My understanding was that indeed media remote should work on this product. Make you you have the latest firmware on the Blu-ray and try also resetting it. In addition have you tried the 'TV Sideview' application as I think this will be replacing media remote moving forwards (albeit Media Remote won't be updated)
