Ive just bought a wall bracket...
lynne.wain
... although the bracket came with numerouse fixing, I've found the four that go into the back of the tv, BUT I have only screwed them in hand tight - any idea on how to be sure the screws arent too long??
Many thanks
Bravia55HX
you should check the instructions that came with the bracket but a safe bet is the screws should not be longer than 16 mm, depending on the size of your panel i would be more concerned how its fixed to the wall and the type of wall you have, i did my old pioneer plasma with self cutting star drive screws as used by window fitters, i know they will never come out.
lynne.wain
Many thanks for that they are in fact just 16mm. The wall is solid and I was supplied with some seriously large 'concrete bolts'.
That's put my mind at rest - thank you again.:smileyhappy:
