KDL 32EX603 USB Port
Gordonro
I have a couple of queries regarding the above.
1. Can I connect a USB hub.  I want to use a wireless dongle and at times connect a memory stick to watch videos, and would prefer not to have to interchange them.
2. Do I unmount the memory stick by turning off power to the TV.
Gordon
HI there
Unfortunately USB Hubs are not supported - therefore USB drives have to be directly connected to the TV.
Turning off the TV before unplugging the USB drive is certainly good practise.  However if you dont do that, just ensure that you are not accessing the USB drive before unplugging it (ie exited out of all media playback).
HI there
Gordonro
Many thanks for the answers.
Gordon
