KDL-32w700b
rahat47
KDL-32w700b
How can I disable X-Reality Pro? every five minutes its appering on the screen which is irritating.
If any one knows please let me know.
Thank you
Hi there
I dont really understand whats going on here, any chance you can take a photo of the message on the screen?  Also, this model TV is not a UK model - What country are you from?
There are two things I can think of here:
  1. You have set the TV up in SHOP MODE - If so, you need to factory reset the TV and choose HOME instead.
  2. Is it "Reality Creation" - If you press HOME, then goto > Settings > Picture Display > Picture Adjustments > Reality Creation - should be able to turn it off their.  See HERE for more informaton.
