KDL-32WE613 HDR (Xbox One S)
darobin76
Anybody know of any way to get a Xbox One S to detect HDR support on this 2017 TV? Forcing it on via TV, the Xbox One S still fails to detect HDR10 support even though my PS4 Pro worked fine and auto detected support as soon as I plugged it in.
4 REPLIES 4
Drewde
Administrator
Have you had a look in the display settings on the XBOX One?
Thanks,
Drew
darobin76
Yes it says it the TV does not support HDR10 (which it does) HDR is selectable from the Xbox One S via checkbox but it does nothing even if the TV is set to HDR already, Enhanced mode is already set on both HDMI ports (I've tried both)
Drewde
Administrator
Thanks for the info.
There a few steps here you can try: https://support.xbox.com/en-US/xbox-one/console/troubleshooting-4k-and-hdr-on-xbox-one
Thanks,
Drew
darobin76
Thanks for the reply I've tried all that already before I posted here. I don't think it's possible to activate HDR as the Xbox expects a 4K display first. Unlike the PS4.
