KDL-40R473A black screen
My TV just black screens now whenever I turn it on. It is completely unusable with no audio as well. The green light comes on and pressing the power button on the remote turns it red.
Mick_D
Moderator
Hi there, welcome to the Sony Community :slight_smile:
I'm not sure if you have power cycled or factory reset the TV, but this would be my first port of call. Have a look at this troubleshooting guide and see if anything helps.
If it's no better, you should contact Sony Support
Hope you get it sorted out
Mick
