KDL-40U 2520 digital tuner is not working properly, I can not find them, what should I do to run a search for digital channels, which country I should ask, what to do.
Solved! Go to Solution.
Hi bigben312,
Have a look at the available manuals here: -
http://www.sony.co.uk/support/en/product/KDL-40U2520/manuals
Hopefully you will find one giving local information.
Hi bigben312,
