KDL-42W653A and Seagate GoFlex Home
MattKotsa
Hi there,
I just got a KDL-42W653A and I connected it to my router via ethernet cable, the same way my GoFlex Home HDD is connected.
The TV detects the HDD but doesnt display all the folder and their contents. I can play the displayed files but a huge amount is missing.
Any ideas ?
Matt
Roughly how many files do you have:
  • In that folder
  • and over-all
EDIT:
Just found what I was looking for:
"The accessible file or folder limit in a directory is 1,000 for USB and 30,000 for a server. This limit includes non-supported files or just folders. Files or folders are populated based on their timestamps. Photo, music files or folders exceeding the limit will not be displayed."  From : HERE
Does this apply to you?
6 REPLIES 6
Hi there
If your files are not on the supported list : HERE  they either wont work, or wont display.
MattKotsa
The files are ok, I copied some on a usb key to try and it works well.
By example, one folder display only the first files/folders up to letter G and no more.
  • In that folder
  • and over-all
EDIT:
MattKotsa
That could be this!! Got a couple of folders that contains my pictures for years!! Need to move all the files I dont want to use on the TV then.
Thanks very much for your help. Ill confirm this soon I get home ! :wink:
Chen1982
I have the same problem with my sony bravia W9. I had the hard drive connected and working until the TV decided to update its self! :cry:
its so annoying as it used to work! i have seen the previous post about the number of files on the hard drive, i dont think i have that many on there, plus it used to work!
the firmware on the hard drive is up to date (that was the problem i had when initially setting it up).
any help much appreciated!
Hi there Chen1982,
Can you please confirm the exact symptoms that you are experiencing.  I know that you said you have the exact same problem but sometimes it can be a different problem, as you have also said that its not working.  Can you please describe what does work, and what doesnt (ie, can you see the folders, can you see some files etc, can you play some files and not others, etc)
