KDL-49WE755 and HDR10 on Xbox One X
FenriCZ
Hello, I have Sony KDL-49WE755 model which acording to specification is HDR compatible TV. I had successfully played with HDR on base model of PlayStation 4 before. Same games which worked with HDR on Sony PS4 wont work at Xbox One X, acording to XONE TV info the TV does not support HDR (specificaly HDR10). So this TV is not true HDR or what is happening here? I bought this TV for HDR support, which now seems to be false information if it only works with SONY products. Anyone managed to get this working?
link to TV´s specifications: https://www.sony.cz/electronics/support/televisions-projectors-lcd-tvs/kdl-49we755/specifications
Thanks for any advice in advance.
Regards Martin
UPDATE: So I got reply from SONY support, my TV indeed suports HDR10, then I talked to Xbox support and they told me, that it is indeed problem in Xbox One firmware, which will allow HDR only on 4k displays. They recomended me to submit Idea on https://xboxideas.uservoice.com/   which I did, so hopefully, the will fix this in some future update if more people will vote for this feature. So anyone with similar problem can go there and find my sugestipon and upvote it or submit your own.
Pascale_F
Moderator
Hi Martin,
Welcome to the community.
Thank you for updating this thread with Sony's advice.
Best wishes,
Pascale
