kdl-55w905a.....usb no sound
paul555
hi all,
kdl-55w905a
arcam sr250 amp
tivo box
cant seem to work out why im not getting sound  through my hi fi speakers when using the usb
on the tv...using hdmi cable from tivo to amp then hdmi from arc output on amp to arc hdmi 1 on tv.......does the usb on tv use audio out optical only?
totally confused
live in hope
paul
Hi there
The TV should output audio via HDMI-ARC via USB directly connected to the TV.  Advise that you ensure that the files on the USB drive comply with the supported video/audio codecs of your TV. See:
http://pdf.crse.com/manuals/13HG900111/EN/codeclist.html#5
