KDL-W805A molded plug void the warranty
maphill14
Hi can some one tell me if I remove the molded plug and replace it with another, will it void the warranty...Thanks
Catmambo
Hi
Its a modification so technically yes and we would not encourage anyone to adjust the power cable in this way. Could you not use an extension cable or something similar?
maphill14
Thanks for the reply.
The problem I have is the W8 is an insurance replacement for my last sony lcd which had a power cable that also plugged into the tv end. As my old tv was wall mounted and cables concealed in conduit this wasn't a problem. The new tv doesn't have enough room between the wall and tv for an extension cable.
