KDL37W5500 HDMI ports
HI guys
for some reason the HDMI ports dont work at all. They were fine now, nothing. The AVs work fine so does the tv. Tried rebooting software upgrade etc but nothing.
Is it easy to fix?
Hi there
A couple of extra things you can try:
  1. Turn TV off from the powerpoint at the wall for a couple of minutes
  2. Try another HDMI cable
  3. Test the devices on another TV just in case, because if all else fails you may need to contact an authorised Sony Repair Centre : Here - As it may be a hardware fault on the ports themselves.
a tried all that. Called sony and they gave me a shop to take it too. But he wouldnt give me a price or whether he will give a replacemrent tv till its fixed
