KDL47-W805A
Lapcius
KDL47-W805A
General
Unique ID                                : 205520577751357869510250518556555037274 (0x9A9DD2D01A8C5A8484A8630950734A5A)
Complete name                            : D:\d\[Coalgirls]_Another_(1920x1080_Blu-Ray_FLAC)\[Coalgirls]_Another_01_(1920x1080_Blu-Ray_FLAC)_[BB945F6C].mkv
Format                                   : Matroska
Format version                           : Version 2
File size                                : 1.50 GiB
Duration                                 : 24mn 42s
Overall bit rate mode                    : Variable
Overall bit rate                         : 8 721 Kbps
Encoded date                             : UTC 2012-05-14 00:44:53
Writing application                      : mkvmerge v5.4.0 ('Piper') built on Mar 10 2012 13:34:39
Writing library                          : libebml v1.2.3 + libmatroska v1.3.0
Attachment                               : Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes
Video
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : High 10@L5.1
Format settings, CABAC                   : Yes
Format settings, ReFrames                : 16 frames
Codec ID                                 : V_MPEG4/ISO/AVC
Duration                                 : 24mn 42s
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Display aspect ratio                     : 16:9
Frame rate mode                          : Constant
Frame rate                               : 23.976 fps
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 10 bits
Scan type                                : Progressive
Title                                    : 01 - Rough Sketch
Writing library                          : x264 core 122 r2184 5c85e0a
Encoding settings                        : cabac=1 / ref=16 / deblock=1:0:0 / analyse=0x3:0x133 / me=tesa / subme=11 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=16 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=12.0 / qcomp=0.60 / qpmin=0 / qpmax=81 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Language                                 : Japanese
Default                                  : Yes
Forced                                   : No
Audio
Format                                   : FLAC
Format/Info                              : Free Lossless Audio Codec
Codec ID                                 : A_FLAC
Duration                                 : 24mn 42s
Bit rate mode                            : Variable
Channel(s)                               : 2 channels
Sampling rate                            : 48.0 KHz
Bit depth                                : 16 bits
Title                                    : Japanese 2.0
Writing library                          : libFLAC 1.2.1 (UTC 2007-09-17)
Language                                 : Japanese
Default                                  : Yes
Forced                                   : No
Text
Format                                   : *****
Codec ID                                 : S_TEXT/*****
Codec ID/Info                            : Advanced Sub Station Alpha
Compression mode                         : Lossless
Language                                 : English
Default                                  : Yes
Forced                                   : No
Menu
00:00:00.000                             : :Intro
00:01:32.008                             : :Opening
00:03:01.973                             : :Part A
00:09:53.968                             : :Part B
00:23:00.962                             : :Ending
00:24:31.011                             : :Preview
 hi, is there any way to play video like this?
Hi there
I would recommend Handbrake - Its a free open source program.  It serves me well, but can be a little difficult to use first up.
http://handbrake.fr/
4 REPLIES 4
Hi there
You will need to convert this file, specifically the audio codec, as FLAC is not supported.  See the Supported codec list : HERE
Lapcius
what program would you advise for that?
Hi there
Lapcius
Thanks, i will try after work :slight_smile:
