Led Bravia ex31
Dr_hisho83
Led Bravia ex31
I have Bravia EX31 series how to play a movie è subtitle from USB ?
Hi there
Without knowing the exact model number of your TV, its very difficult to help. But the first thing I would do, is consult the manual (either the paper verson, or the onscreen versions)
You can also go to the link below, click on the model number and download/view the manual -
http://www.sony.co.uk/support/en/hub/LCD
Cheers.
Bravia55HX
you cannot play any subtitle files to your movies unless you use a media server such as Homestream or Serviio, and even then you must make sure your subtitle files are exactly the same name as the movie file with the .srt extension.
