Navigating in BBC iPlayer
fzmvtx
Hi, just got my new TV so am trying to find my way around all the features. My question is how do I navigate back from a selection in the BBC iPlayer application. Some of the screens have a "back" option which is great however ther are occasions when this is not available and pressing the return (back) button on the remote does not work. Am I missing something or do you have to go back to one of the available options and start again.
Thanks.
Catmambo
Should be a back button on most pages, it would be a software button on the screen provided by iPlayer I think as you are correct, the return button on the remote doesn't necessarily correspond to return on the screen.
