No HD, FHD or UHD quality on SONY XE7077SAEP Youtube app?
profile.country.RO.title
ionutm80
I've noticed that when watching Youtube videos on the TV app all the streams are limited to SD quality (360p or 640×360) at stated by the nerds stats. Does this mean that the TV does not support the decoding of VP9 which is shown as the default codec for Youtube videos? Meaning that not even 720p or 1080p Youtube videos are possible whith the Youtube app? This would practically make unusable the Youtube app on a 4k TV like this. For Netflix and Amazon which uses HEVC h265 I have no problem watching 4k 2160p with the embedded TV apps.
Mick_D
Moderator
Hi ionutm80
I'll check this out for you and hopfully gat an answer soon. Meanwhile someone else may be able to help :slight_smile:
Regards,
Mick
