parental lock password
deonix9
Hello,
I'd like to know how can I cancel, overwrite a preexisting password, parental lock, for Sony KDL-32W705B.
Thanks.
Hi there
  • Press the Menu button on the remote control
  • Goto System Settings > Parental Lock > Pin Code
  • Enter the pin code that you set originally.   If you cannot remember your pin code, enter 9999
  • The pin code can now be changed.
Hi there
deonix9
Thank you.
Your most welcome :slight_smile:
