Play back and record to dvd??
Less2222
Hello,
I have a Sony Bravia and I usually record programs to a hard drive via usb.
However, there are programs I would like to save for the future and I'd like to save them onto a dvd. I do have a dvd player. My question is... can I play back the program and record it on to a dvd via the dvr (since the hard drive only works with this tv)?
Thank you
Bravia55HX
in a word, no. Its because the hard drive is "registered" to the tv so any material you record to it can only be played back by said tv, you will not be able to transfer anything recorded to your hard drive to dvd unfortunately.
Bravia55HX
