Problem connecting to video internet on KDL-32EX713
Mango99
I have set up the Sony dongle to connect to my home hub, which it tells me was successful. But when I go to video internet download I get the following error message 'Configuration failed while connecting. There is no link. Please check cables.'
Can anybody explain?
4 REPLIES 4
Pcadjb
Hello,
           Sorry not an expert on this, but have you checked out the following on the Sony UK website?
http://sonycic.custhelp.com/app/answers/detail/a_id/1042/kw/uwa-br*/related/1
Hope it helps.
profile.country.en_IE.title
evan121212
i have also the same problem with my KDL 55EX503, it wont connect to the internet though im using a cable not wifi signal. did u get things sorted out? because mine is not yet done. thanks.
Bladettes1981
did  you get this sorted? please help! ive just posted a thread re same.....
Mango99
I used a cable to do the first installation which allowed the software to load. Since then the TV has worked fine with the dongle.
I hope that works for you.
