Question
biglad67
Question
Can you connect Sony bravia KDL-40EW524 to a hi fi? If so what do you need to connect ?
Bravia55HX
well there may be a couple of options available here depending on what model hifi you have, if it has an optical connector and if your tv supports it, while were at it can you confirm model number of tv as the one you posted dont exist!, the other of coarse is the plain old phono leads (red and white) from your tv to the hifi.
biglad67
Sorry you're right EX524 40inch tv
