Re: USB connect & play
zedkuk
HELLO.
I Have bravia kdl 40ex403 and the usb is not detecting. im using WD HDD 1TDB. it is not giving display in hdmi or video or pc slot. the usb is detecting as the usb light is on. kindly advise asap.
thanks
Hi there
You need to press the home button on the remote control, scroll across until you find videos, the select USB, and you should see what ever video files there (assuming they are supported for your TV)
