RM-AAP063 and Virgin media v+ box (Samsung)
Crooklar
I asked this question on twitter and I've been pointed here, hopefully you can help:
@Jon_darling: @SonyUK why does my remote not exist according to your website? I would like to program it with a Virgin V+ box 1/2
@Jon_darling: @SonyUK there are no codes online or in the manual, remote came with STR-DH820, a Virgin cable box also is not listed on your web page 2/2
5 REPLIES 5
HI there
The best I can come up with is the american site : HERE.  For anything else, I would suggest you contacting Sony Support : HERE.
Bravia55HX
you cannot control your Virgin box using the RM-AAP063 Sony remote, sorry
Thalamus.
Champion
Hi Crooklar,
welcome to the Sony User Community Forum..:smileyhappy:
Depending on your remote, supplied with your Virgin Media box, you should be able to program the Virgin Remote to operate a limited amount of options on your Bravia, see here for more info - Virgin Media Remote Control Codes
Bravia55HX
Thalamus
thats not the answer to the original question though, is it :wink:
the Sony remote for the STR-DH820 Amp will not control a Virgin set top box.
Thalamus.
Champion
@Bravia55HX wrote:
Thalamus
No it is not you have answered that, but, I thought it was worth mentioning though..
