Screen Mirroring Question
tanbir17
I use to have the tv connected via wifi and today I decided to have it on the wired option.
By having a wired connection I have noticed screen mirroring is not working. It use to work perfectly when it was on wifi. Both the wifi and wifi direct options are on under the settings.
Can anyone confirm if I can have screen mirror on whilst have a wired connection.
gofrost
You will have to reset the connection from the TV from wireless to wired and then pair device to tv
tanbir17
What do you mean by resetting the connection from wireless to wired?
The Tv is already setup is in wired connection. I tried the screen mirror, but the phone is unable to see the TV!
Sebek74
I believe they establish peer-2-peer wifi connection  somehow.
I'm using Sony Tablet Z and observed that too.
Are you experiencing ~1 second lag between TV & device? Playing games is really hard due that issue.
