Sony 50X94S Audio
Azzzza97
Sony 50X94S Audio
Back in January I bought a 'Tech' Sofa, which had built in bluetooth speakers. My TV at the time did not support bluetooth, so I bought a bluetooth Transmitter Receiver, 2 in 1 Portable Bluetooth Wireless Adapter, which worked brilliantly.   I have now replaced that TV with a Sony XR-50X94S. I have connected the TV's bluetooth to the sofa and the volume is so low.
Does anyone know if there are any settings that will improve the bluetooth audio?
Or would purchasing one of these Bluetooth Adapters work?
The new TV doesn't have a headphone socket, so can't use the adapter that I previously bought.
Any help would be appreciated.
8 REPLIES 8
royabrown2
Hero
@Azzzza97
That appears to be a Windows device, and so will come with a Windows driver, not a driver for your TV.
i take it you can’t just turn your Bluetooth volume up?
Azzzza97
Hi royabrown2,
Thanks for your response,  I never even read the description 🤦‍♀️.
If I play out of the TV speakers, the volume is fine at 17, however, to get to the same sort of level of volume, the bluetooth volume has to go up to 40.  Seeing as it's quite a difference,  I would hope to find a fix, otherwise I'll not be having the audio coming through my sofa speakers, which is a shame.
royabrown2
Hero
@Azzzza97
I don’t know if this setting, or one very like it, would affect the Bluetooth volume?
https://www.sony.com/electronics/support/articles/00180150
Oerhaps worth investigating, though.
Azzzza97
So a wee update.  Sony suggested connecting to a different bluetooth source.
I have therefore now connected my Sony WH-1000XM3 headphones and as soon as they connected, the bluetooth volume shot away up to 66.
So it seems even though the TV speakers can be as low as 17, bluetooth needs to be a lot higher.
royabrown2
Hero
@Azzzza97
You have seen ‘Spinal Tap’? 😛
Azzzza97
Have no idea what this is 🤦‍♀️
royabrown2
Hero
See below
royabrown2
Hero
@Azzzza97
https://www.youtube.com/watch?v=4xgx4k83zzc
What the volume control says is not always what the volume actually is 😛
Spinal Tap lead guitarist, Nigel Tufnel explains the importance of going to 11... 2021 update: I'm now planning to actually make something of this channel, so please subscribe for more random content like this & check out my website to see what else I'm up to: https://www.stillo.co.uk
