Sony Bravia 49XE70 4k best settis for ps4 pro
jambobicans
I need to know all the settings I should put on for my ps4 pro to be used to the best quality, i am not too sure how to get it perfect, I have it in hdmi enhanced etc but want to know the exact best settings to get the best quality for the ps4 pro? Thanks
Owen_G
Hi there. Your console will auto select the best settings for your TV. You might also want to check if there's a 'game mode' or similar in your settings on the TV itself? Hope this helps.
Thanks,
Owen
