Sony Bravia KDL-40HX753
adiyaya
I have returned home tonight to discover that my Sony Bravia isn't finding the built in wifi.  I have reset the TV to factory setting twice, as it seems to work.  This time it seem to be the actual built in wifi not the ability to connect!
Does anyone know what I can do to sort it out!  :slight_frown:
Thanks in advance.
Hi there
Try turning off your router for 5 mins, and switching it on again.
If that fails, does the TV even find your network?  How many "bars" does the TV show for signal strength?  Are you able to "wire" it up as a test?
