Sony Bravia KDL42W654 - Wall Bracket size/type ..bet none can answer this :)
tuktuk1
Have been scouring the internet for the last few days trying to find the answer.
What kind of wall bracket is compatable with the KDL42W654 ?....eg vesa 300x300 etc
12 REPLIES 12
glospete
I have purchased one of these Sony Kits from Vogel from AV4Home and it works perfectly. At £18.95 it's a bit pricy for a set of bolts but now my KDL-50W815 sits perfectly on its Zental stand. Couldnt wait for the Sony item, and now I'm not sure I'll even bother with it.
Vogels W6:7:8 sertvice kit - AV4Home.png
I want to mount tv on wall cann you tell me where to get one how much and model number I want the swivel one on the courner it's the 40 inch tv thanks
HI there
Without knowing your exact model number, I cannot advise you on what you need.  However the following page has information that will assist you.
http://sony-eur-eu-en-web--eur.custhelp.com/app/answers/detail/a_id/28858/kw/
Just find your model number on that webpage and it will tell you want you need to do.
