Sony Bravia smart TV - internet connection breaks down
profile.country.IE.title
omnavan
I have a Sony Bravia smart TV connected by ethernet cable to Virgin Hub3.0.  When TV is unplugged I have >200Mbps download and >20Mbps upload speed - excellent broadband.  Once I switch on TV internet connection breaks down
05/07/2017 17:25:55 Log Start ---------------------------------------
Failure Start       Length
05/07/2017 19:46:39 0:06:37 05/07/2017 19:54:29 0:03:23 05/07/2017 20:00:20 0:03:37 05/07/2017 20:06:57 0:03:14 05/07/2017 20:11:26 0:03:17 05/07/2017 20:15:22 0:03:37 05/07/2017 20:24:26 0:03:54 05/07/2017 20:34:24 0:04:35 05/07/2017 20:44:27 0:15:58 05/07/2017 21:05:51 0:10:02 05/07/2017 21:16:32 0:03:20 05/07/2017 21:22:20 0:03:16 05/07/2017 21:26:50 0:37:56 05/07/2017 22:08:25 0:52:46
Hello there
The first two steps in the troubleshooting process is:
  • Ensure that your TV has the latest firmware installed
  • Factory reset the TV
Unfortunately you havent listed your TV model number so I cannot give you instructions on how to do so.  If you need instructions and/or the above fails to fix the problem, please reply back with your TV model number.  Also are you using wireless or a wired connection?
omnavan
Thank you for prompt reply.  TV model is BRAVIA KDL-40W605B.  I am using wired connection.  Previously I was using wifi connection - the same problem.  TV wifi is switched off.
