Sony HX720/723 dimming
profile.country.el_GR.title
techlove
I want to know where the leds are located at 40 HX720. Up, down, only down, left and right? Where? Also is there any kind of dimming? If yes, what type? How many zones? Because Hx750 has frame dimming and I think that HX750 leds are only down.
Thanks!
5 REPLIES 5
profile.country.FR.title
ClarkLong
Hi techlove.
The 40HX720 is a Dynamic Edge LED...which means that LED are all around the frame. Up, down, left & right :wink:
It also has a local frame dimming  feature for the LED around the screen
techlove
Dynamic Edge LED are HX750 & HX850 also but they don't have all around the leds...
ClarkLong
That's not because you can't see the LED that they are not there :wink:
I saw a teardown HX850 in Sony HQ..and I can assure you that there are LED ALL AROUND the frame :slight_smile:
techlove
HX850 has leds at left and right sides, only!
ClarkLong
techlove, I just had confirmation from Sony that LED in the HX
850 are only on the vertical sides...I guess I saw a mock up but not final products... :slight_frown:
