Sony KDL- 32U2000 - TV Settings with Sky
Bdazzling
Hi, I have had this tv for about 6 years and its always been used with my sky box. However I went on holiday last week and when I came home there is a problem. It's nothing major, just annoying. When I turn the TV set on it always went straight onto the Sky channel, however now its gong to channel 00 and I have to use th TV remote, which I have never done, and press the button on the top left to switch it to the hdmi channel to watch sky.
I asked the people who were here last week and they all say they didn't do anything, just turned TV on but I think somehow they've altered the settings.
Can anyone please tell me how to set the tv so it automatically comes onto the sky channel when I turn it on please.
It's not a big issue for me but my OH struggles trying to see the buttons.
Thanks for any help
Hi there
There are no settings on the TV to automatically select the HDMI source, however I believe that there is specific remote codes for the sky remote to enable this.
  • Press TV
  • Hold SELECT and Help (red light on remote control should flash twice)
  • Press HELP repeatedly until you find the correct AV input you want
  • Press SELECT
Then...
  • Press TV
  • Hold SELECT and GREEN (red light on remote control should flash twice
  • Press HELP once (nothing should happen
  • Press SELECT to store
I cant verify this as I do not have Sky,
Hope that helps
Hi there
  • Press TV
  • Press SELECT
Then...
  • Press TV
Hope that helps
