Sony KDL-47W805A
profile.country.BG.title
Krasimir00
Sony KDL-47W805A
Hi, just few days ago I bought Sony KDL-47W805A TV. I tried to watch a movie from a USB flash card but it didn't load it. After some testing with different formats I noticed that can't load FLAC files. Is it possible to to install a new codec for the FLAC files and how. And forgot to tell that I've updated the firmware to the latest one.
Thank you for your help.
Catmambo
Hi
No native support for FLAC im afraid. Quite rare for movie to have a FLAC soundtrack, normally its mp3 or AAC which are supported. Could always convert it via Handbrake or something similar?
5 REPLIES 5
Catmambo
Hi
Krasimir00
From what I've checked the full HD blu ray movies most of them are FLAC. And about this program it's not so nice to wait 40-50 mins to change this format. I was wondering is it possible to boot the FLAC codec from a USB to the TV ?
Unfortunately it doesnt work that way.  You cannot add/delete/modify installed firmware/codec support on the tv at all.  For a list of supported codecs see : HERE
As Catmambo said above, it might be best to convert the the movies to a playable format.  Its not just changing the format, its re-encoding the movie (especially the audio) into another codec.  However with Handbrake, you can set up multiple movies/files at a time (or even the whole folder) and then just let it run over-night or so.
Krasimir00
Ok, thank you for your help explanations. I'm sorry about those probably stupid questions but I don't know much about TVs.
Thats ok, and besides, there are no stupid questions (except for when I ask them, that is)
