Sony KDL40EX403U - Safely remove USB deviec message
rkdirdsd
Every time i unplug a USB drive from the TV I get a warning message on the  screen saying
"Do not unplug the USB device that is still active"
How do I disable the USB device so it is safe to remove, I have looked through the menus and cannot find a way to do this. Otherwise everytime I pull out a USB drive it could damage the filesystem as the TV keeps it active.
drm765
Bump!
I've just asked the same question of Sony's support and the answer is that safe removal of a USB device is not supported!!!!!!!!!!!!!!! Their advice is TO SWITCH OFF THE TV. INCREDIBLE.
David
drm765
Bump!
David
