Sony KDL42W829BBU no built in 3D video converter?
jpop_81
I got one of these yesterday, the 2D picture is fantastic, but it doesn't have a 2D to 3D video converter built in. Can I buy a converter box? I'd like to be able to convert 2D tv from a Sky HD box(HDMI connection) into 3D.
Hi there
Page 23 of the manual : HERE, says
Available Options
Various settings and playback operations are available by pressing OPTIONS. The available items differ depending on the situation.
Common options
[Repeat Setting]:
Sets the repeat mode.
[3D Menu] (BDP-S4200/S5200 only):
– [Simulated 3D]: Adjusts the simulated 3D effect.
– [3D Depth Adjustment]: Adjusts the depth of 3D image.
– [2D Playback]: Sets playback to 2D image.
I have no other information in regards to USB playback.  I cant see why not, but cannot guarrantee that.
Best thing to do, is test it for yourself im afraid.
Hi there
You are correct, this model does not have the "3D Simulation" feature : http://www.sony.co.uk/electronics/televisions/w800b-series/specifications
I am not aware of any simulated 3D converters that would do the job you require it to do.
PS: As a personal note, Ive always found 3D simulation to be...well...rubbish?
jpop_81
Thanks for the swift reply.
I have a Sony BDP-S5200(came free with the TV) I havent opened it yet as I thought the TV may go back. It says it can convert 2D movies into 3D, will it be able to convert movies from the USB port?
Hi there
Available Options
Common options
[Repeat Setting]:
