Sony KE-42TS2E TV - What exactly do I need to connect an Android Box?
dstraker
Hi All
I am looking to connect my TV - a Sony KE42TS2E Plasma - to an Android box in order to stream programs from Netflix, ShowBox, etc. on the big screen.
The TV does not have an HDMI port - it's old, but in good condition, and I don't want to throw it out as that's an outright waste. I have found a lot of information on Android & MXQ boxes online, and on HDMI to AV converters, but nothing product specific and I am reluctant to go spending money until I know exactly what I need.
I would be most grateful for any guidance that anyone here could provide on the matter...
Thanx in advance & anticipation
David.
Hi @dstraker
I have moved your post to the correct area on the forums.
This is the part where i say - nothing can be guarranteed, simply because you are wanting to plug new technology into old technology.
You will probably need one of these:
https://www.amazon.co.uk/Tendak-Component-Converter-Adapter-Coaxial-x/dp/B01EL6DNES/
Have a look at the product description and reviews.
lidann
really if you want to stream those movies apps like Netflix, Terrarium tv updated apk ,showbox then buy one of the best firesticks from famous brand amazon
